rear end vibration, pump not shutting off
GarrenJ
09-18-2004, 06:37 PM
I have a 99 silverado. the rear end starts bouncing when the brakes get warmed up. I have replaced the pads and tires but still no change. Also, last night when I shut my truck off I heard a humming noise from under the truck. It is a little box with hoses coming out of it. I had to unplug the wires to get it to shut off. Can anyonehelp me? Thanks
draboo
09-18-2004, 07:27 PM
sounds like your rear rotors need turning/replacing. i would suggest replacement.
i dont know what the black box with wires would be. where exactly is it located??
also,does your truck have duel fuel tanks??
and is your truck a new or old body style (1999)?
GarrenJ
09-18-2004, 11:06 PM
no, I have a single tank
It's not neccessarily a box. It looks like a pump of some sort. it is located on the frame under the truck, almost directly under the drivers seat
Yo Dog
10-01-2004, 06:09 AM
That box making the noise is your anti-lock brake controller/valve. Sounds like it needs replaced. If im not mistaken its pretty expensive. Im also guessing yours is the new body. Hope this helps.
