98 Suburban wont start
ed98
09-17-2004, 08:41 PM
Help pls......my sub wont start. Changed the rotor and cap, newly tuned-up, battery is on full charge, alternator 'bout year old, starter 'bout year and a half. When I turn it on it just clicks....:(, banged the starter a few times but didn't work.....anyone out there with a tech-know-how on what's wrong?......
Jeremy-WI
09-18-2004, 08:23 AM
check and clean battery connections, the side posts are notorious for corrosion and even loosening on their own
ed98
09-18-2004, 03:35 PM
ty but i already did that even checked the solenoid connections but with no luck, now it justs clicks....:(
chuck's
09-19-2004, 11:46 AM
Couple of suggestions.You've checked +ve and -ve on the battery,+ve on the starter, but have you checked the -ve to the engine block.Also if you have a multimeter, I would check and see if the power is going across the soleniod contact to the starter motor.You could have burnt contacts in the solenoid and the power is not getting to the starter.
chuck's
gcayetano
11-15-2004, 12:40 PM
I'm having the same problem. I would clean the battery for corrosion, but sometimes there are none. This will only be temporary until a 1-3 month later, then it would start all over again. I'm thinking about replacing the battery cables.
Pakeboy2
11-17-2004, 04:48 PM
We had the same problem 2 weeks ago. We had to change the starter out. We paid $140 for the starter at the local dealership here in town
