Pulleys
andrewespo
09-16-2004, 08:43 AM
I just picked up a BBK pulley kit for my 88 GT. My question is once I get off all the bolts and nuts how much do I torque them on the alternator, water pump, and crankshaft. Also whats the easiest way to get the crank pulley off, it seems like a tight squeeze.
Thx for help.
Thx for help.
HiFlow5 0
09-16-2004, 10:49 AM
Take off the fan and fan shroud, that should open you up to a lot more room. Also loctite the bolts to the crank pulley.
StangNut86
09-16-2004, 11:16 AM
thread whore!
i just installed my underdrives, and now my car charges like shit. about 9-10 on my voltmeter. what would you guys reccomend for an aftermarket alternator?
HiFlow5 0
09-16-2004, 12:45 PM
Whore!!!!!!!!
A 3G upgrade is what people usually do.
http://fordmuscle.com/archives/2001/03/paperformance/index2.shtml
I have underdrives on both my cars with no charging problems, but the alt and battery are new on both, so a weakened alt could have adverse effects. At idle mine charges at 11 volts and 14 while driving.
StangNut86
09-16-2004, 03:40 PM
i can get a 3g off a local guy... prolly the route i'm gonna go.
andrewespo
09-16-2004, 04:52 PM
Installed pulleys, treadlocked bolts on crank. All is well no charging issues.
HiFlow5 0
09-16-2004, 05:41 PM
:bigthumb:
:bigthumb:
wildstringer
09-16-2004, 06:08 PM
i only got thee two piece set for fear of that same problem stangnut is having then i saw a 3 piece set that claims not to have any charging issues , anyone know if its true or just a gimick? as far as the torque for the alt. i ve always just give the nut a couple quicks zaps with the impact and never had any troubles.
StangNut86
09-16-2004, 06:29 PM
i'm having charging problems because i'm running an 90 thousand mile alternator. it happens =P
wildstringer
09-16-2004, 08:31 PM
oh yes i guess it would tend to .lol
StangNut86
09-16-2004, 09:11 PM
just got my 3G, gotta get a grinding disk and some crimp connectors and i can install it.
kittedb18bt
09-16-2004, 09:22 PM
i thought you had to use a special wrence to get the alt pulley off. is it an impact wrence?
wildstringer
09-16-2004, 09:35 PM
yes an impact wrench will take the alt pully off
andrewespo
09-16-2004, 11:27 PM
To get the alt pulley off I used a ratchet and a rubber mallet and hit the ratchet attached to the nut until it came loose, took some time but I was determined to get it off.
MARS
09-19-2004, 07:20 PM
Did you FEEL any hp gains?
andrewespo
09-19-2004, 08:05 PM
I feel that the car has faster acceleration. Throw in the pulleys with a combo upgrade for overall hp. You'll have a lot more noticable horespower feeling. I put most of my bolt on's piece by piece so the feeling is less noticable.
Future303
09-19-2004, 11:12 PM
I noticed a boost also, it's like the car suddenly got lighter. It was a bigger difference than I expected. I'm not sure if acceleration is any faster, but the engine on it's own does rev up faster, and also drops faster (trickier to use clutch)
351wStang
09-20-2004, 09:09 PM
Speaking of a 3G alt. If I use a ministarter and 1 big battery or 2 decent sized batteries in the trunk of my '66 for my 351 build should I need an altenator better than stock? I'm thinking of somewhere around 1000cca.
91notchback
09-21-2004, 11:00 PM
yeah i also have charging problems, i sit at like 9 or 10 volts at idle. my batteryis also a pile of ****. personaly I'd trade my for stock pullys.
