abs not working
aznbmxxxer
09-13-2004, 09:56 PM
my abs light came on when i put a new engine in it. the code is 4 short blinks and 1 long blink. the haynes manual says its the speed sensor. how do i fix it? i have a 94 integra ls.
hundahunta
09-18-2004, 01:18 AM
possible you pinched a wire or stretched a wire causing a internal open in the speed sensor wire. checked all your connections.. find a mutimeter and check the resistance of you wheel speed sensors, does you vehicle speedometer work??
aznbmxxxer
09-21-2004, 05:47 PM
yea the speedo still works, how do i check to see if the wheel sensor is still working with the multimeter?
silky4u
10-06-2004, 03:27 AM
You could possible have a pressure leak, or a low fluid level, kinked hose or anything otherwise that would give the control unit a low pressure reading. The ABS system utilizes a pressure switch which sends a pressure signal to the control unit. If the control unit senses this then a fail-safe relay disconnects the solenoid valve ground circuit to shut off the valve and illuminate the idiot light. I would of suspected a tone wheel but I believe (correct me if i am wrong) that the speedo is also operated off of the tone wheel, so if the speedo still works then it sounds like a pressure problem.
