some explination please...
lazysmurff
09-12-2004, 11:57 AM
heres the deal. ive started saving for a project car, and im looking into a 91-93 integra (i think they look keen) but id like to switch engines (who didnt see that comming?). ideally, id like to drop in a newer LS engine and go with a vortech supercharger. now the question is
can i keep the original tranny with the newer ls engine...could i keep it even with a newer GS-R engine...would i want to keep it? whats the difference in gear ratios between all the trannys? basically, i want to know if i can get away with just an engine swap, of i need to save for the whole thing. (keep in mind, i road race, i dont drag all too much)
tran_nsx
09-12-2004, 03:19 PM
because ur staying with the b-series motor, whether it be the b18b1 (94+ ls) or the b18c1 (94+ gsr) there shouldn't be a problem keeping the original transmission. would u want to keep it? thats up to u. gsr trannys have a shorter gear ratio causing it to rev acutely quicker in rpms' thus making it accelerate faster than the longer ratio of the ls. if u have the money and think this is a good idea, go ahead. if u want to save money since this isn't going create a huge difference between the two tranny, stay with the ls.
tran_nsx
09-12-2004, 03:40 PM
check out the lets get technical forum, they should have more info on transmission.
wickedplastikman
09-12-2004, 05:40 PM
lazysmurff
09-12-2004, 10:10 PM
so, the smaller the number the taller the gear ratio then? cuz all the numbers on the GS-R tranny are larger then the LS tranny. (though there isnt too much difference, i think i will stay with the LS)
Thank you both.
Thank you both.
integralover
09-12-2004, 10:42 PM
from what i hear the LS tranny is best for the trubo/supercharger app. but the syncro's in our transmissions suck.
superbluecivicsi
09-12-2004, 11:45 PM
If you drop in a 94 ls motor in. You will need a hydro tranny. You cant swap a hydro into a cable. If you swap out the motor, just get a complete swap with the tranny. Itll save you the xtra work from converting the hydro into a cable.
superbluecivicsi
09-12-2004, 11:47 PM
see if you can read this..........
http://www.hondaswap.com/forums/index.php?showtopic=29829
PS: Look at this for the reference and tranny swapping possibilities.
tran_nsx
09-18-2004, 01:45 PM
damn, totally forgot about the difference in trannies. :banghead:
knorwj
09-18-2004, 07:08 PM
shouldn't matter if the motor was originally coupled to a hydro tranny or not, a motor is a motor. you can take a newer motor out of a car that had hydro tranny and hook it up to your car with cable tranny no problem. if you swap in a newer tranny though that is hydro and get rid of the cable tranny you will need to do some work .
tran_nsx
09-18-2004, 11:38 PM
hhmm. im going to have to do some research on this, i know that they have different trannies from the sec to the third gen. so something tells me this won't just be a simple engine swamp, one example, they have different ecu's. again about the tranny, i might be wrong, guess i'll have to find out.
