window and door pannel problems
shebeems
09-08-2004, 12:00 PM
I just bought a 93 bmw 328 and when I went to open the door today the panel came off is there any way of fixing this or do I have to buy a new door pannel? Also my passanger window was acting up and when I would put the window up it would make a clicking noise when it was up all the way, now the window will not go down at all! Any suggestions?
bimmerman333
09-08-2004, 12:20 PM
no you need new gromets for the door panel, fairly cheap fix, window could be a bad switch,or comfort relay.
Antiburn
09-08-2004, 02:39 PM
You need a window regulator. Once the noise starts you know you need one. Now it work work you do need one.
For the door pannel you have to look at the little plastic clip ons, if they are all broken then you need all new ones. Just buy as many as you have broken.
And please make sure you have them all lined up before you start hitting them in or you will break them all over again.
shebeems
09-08-2004, 09:53 PM
Thank you for all your help!!!
