New rims
bh04
09-07-2004, 09:46 PM
If I were to get some 17" rims, and I have stock right now on a 2000 Cavalier 2.2, which have 14", I've heard I would have to get my speedometer redone or whatever bc of the size difference in wheel size. Is this true? Would I have to lower my car? Would it be better to?
KustmAce
09-07-2004, 09:58 PM
Your speedometer will be off by probably aroun 5 mph with 17's. You can have it recalibrated, or just adjust. Ive got 16's and mine is off by about 3mph.
Also, your car will look like a whole new, insanely beautiful car if you lower it. It will also handle much better too.
bh04
09-09-2004, 12:00 AM
sweet, thanks for the info
Sight N Sound
09-09-2004, 03:21 AM
That is not correct. If you go with 17's you have to buy a lower profile (thinner side wall) Tire. For 17's you want a 45 series tire. Something like 205/45/17 or 215/45/17.
J-body.org has a tire mesurement calcualtor and gives you the off set if any of the speedo.
I went from the same 14 inch rims to a 17 took it to get calibrated and the dealership said it was ok and on target.
EDIT here is the link. If there may be a offset its only .3 to .6 of 1 MPH off.
http://www.j-body.org/forums/read.php?f=42&i=12684&t=12684
Classicrocjunkie
09-09-2004, 10:08 PM
uhhh... the 205 are the worst! DO NOT GET THOSE!!! Everyone reccomends the 225/45-17 or the 215/45-17 if u cannot afford the 225 off the bat. I wish people would reaserch before the posted wrong info!
Sight N Sound
09-09-2004, 10:25 PM
Its all a matter of preferance. the 225 rub on SOME cavy's inner wells sometimes thats why I went with the 215.
If you are not refering to me fine, But My stuff is researched. I have been doing this for a while
