my mbc please look
scottsee
09-03-2004, 07:02 PM
is this hole in the fitting suppose to be there, i was intalling it, and found it, and need to know if i have to get a new fitting, or what, im a little pissed.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/156077mbc.jpg
96TSi
09-03-2004, 07:17 PM
yeah, its just a relief hole
mine doesnt have one but it makes no real difference
http://webpages.charter.net/kvarner/Pictures/MBC.jpg
*EDIT* this pic was made for this thread, not the off topic pic thread :D
scottsee
09-03-2004, 07:28 PM
thanks for the quick reply. i just got back from going around the block. seems to work fine.
96TSi
09-03-2004, 07:31 PM
do you have an aftermarket boost guage? what psi are you running now? is it on a 1g or 2g?
97dsmeclipse
09-03-2004, 07:44 PM
he has a 2g, or atleast that is what is in his profile.
96TSi
09-03-2004, 07:58 PM
heh thanks :D
scottsee
09-04-2004, 12:23 AM
well before i put the mbc in i was spikeing 20psi, then leveling out around 16. after 9 months of owning the car i never went wot through 2nd & 3rd gear pulls, last week when i finally went wot i was spiking 21 & leveling out a17psi all the time, pluss i noticed boost creep upto 20.. so i figured i needed to install this mbc. im right around 15 now.
scottsee
09-04-2004, 12:36 AM
check engen lights on. is that suppose to happen when you disconnect the Boost controle silinoid and intall a boost controller?
kjewer1
09-04-2004, 12:46 AM
On a ball and spring type MBC, you need that hole. Heres why. You get into boost, go over your MBC setting, and the ball pushes against the spring and lifts off the seat. Pressure gets to the WGA and regulates boost. YOu let off to shift, boost pressure drops, and the spring seals the ball against its seat in the MBC. Guess what? The WG is still open ;) That relief hole allows that trapped pressure to escape allowing the WG to close after a shift. Too large a hole can cause spike, to small a hole does something else thats bad, but I cant think of it :icon16:
EclipseRST
09-04-2004, 08:32 AM
its like a mini BOV for your boost controller :lol:
dsmodder
09-04-2004, 10:28 AM
who makes that mbc scot?
scottsee
09-04-2004, 10:12 PM
so, should my check engine light be on? because i dissconected my boost controlle sylinoid and wire tied it to a hose?
joemathews
09-04-2004, 10:25 PM
I didn't get a check engine light when I hooked mine up...get your code read at Autozone with their OBD-II cable and that should tell you what tripped the CEL.
RiceRocket18
09-05-2004, 12:06 AM
did you disconnect the battery while you did the installation?... cause that might've been the problem.
scottsee
09-05-2004, 11:43 AM
yeah, didn't do the battery. why would that throw a light?
RiceRocket18
09-05-2004, 05:30 PM
when you disconnected the intake which also requires you disconnecting the MAS sensor. and by disconnecting the sensor without disconnecting the battery first sometimes the ECU gets confused and throws a check engine light. which is why i started the habbit of disconnecting the battery whenever i work under my hood now.
should be able to clear the CEL by disconnecting the battery.
joemathews
09-05-2004, 05:40 PM
He shouldn't have had to disconnect the intake or MAS if he were just connecting the mbc...if he did the dump tube hack at the same time, that might have triggered something. Try disconnecting the batter like RiceRocket says, and see if that clears the code; if not, that's when you go to autozone :D. It's funny how sometimes these things randomly happen when we are modding, yet they can be unassociated with any mods we do, just pure timing and luck!
scottsee
09-05-2004, 08:27 PM
thats true. i had to dissconect the maf becasue i did take my injen pipe off to easly get my needle nose pliars on the vac clamps, and to disconnect my bcs. im stupid for not dissconection my battery though. should always do it, i dont know what i was thinking.
kjewer1
09-05-2004, 09:39 PM
You should actually disconnect the battery as seldom as possible. It just makes you drive for a couple days without optimum settings as the ECU relearns. I avoid it as much as possible. Better to have a logger handy so you can just clear the DTC without having to interupt power to the ECU ;)
scottsee
09-05-2004, 09:40 PM
well, i did dissconnect the battery, worked. good enought, its monday tomarrow, it will be good for the stip by friday
