turn signals and backup lights not wotking
kidsheline
09-03-2004, 02:08 AM
I replaced the passenger side tail light assembly recently, and now have a big problem. My turn signals (front, back, and dash indicators), and my backup lights aren't working. I 1 bulb that had a burnt filament, and basically didn't touch anything else. I have checked the fuse(fine), and checked all sockets in that assembly for power and ground (yes to both).
All the other lights are working fine, and everything was working properly before i replaced the housing assembly.
Any help would be much appreciated.
Thanks, kid.
Thanks, kid.
Future303
09-04-2004, 02:40 PM
Man, are you sure you checked the right fuse? I had the exact same problem, and I tracked it to a wire touching metal under the dashboard.
wildstringer
09-05-2004, 11:55 PM
do the hazards work??
kidsheline
09-13-2004, 09:02 PM
Got the problem fixed. Turns out the contacts at the egnition switch had spread apart and weren't making good connection.
