MAP sensor
grease monkey girl
08-30-2004, 01:00 PM
where do I locate the map sensor on my 87 iroc?
Deadcarny
08-30-2004, 02:30 PM
map sensor is on the intake. it is rectangular in shape.
4onFloor
08-30-2004, 08:54 PM
i thought IROC's had tpi motors? if so, it should't have map sensor, should have a maf sensor
Genopsyde
08-30-2004, 10:06 PM
I thought it had both.
Deadcarny
08-30-2004, 10:39 PM
all EFI cars have a MAP sensor.
4onFloor
08-30-2004, 10:53 PM
only pre-1990 have MAF sensors 90-92 use MAP. on third gens it was one or the other. tbi uses speed density, while 86-89 tpi used MAF, they dont have both MAP and MAF sensors
grease monkey girl
08-31-2004, 01:05 PM
well, my code is flashing that there is a MAP sensor problem and the parts store sold me a MAP sensor specifically for my car, the book shows that it should be located on the firewall attatched with a bracket, but I can't find it.
4onFloor
08-31-2004, 01:41 PM
yes it should be mounted to a bracket that is mounted to the firewall to the left of the distributer, has a green 3 wire connector and a plastic vacuum line on the bottom.....but only if you have tbi. if your motor is tpi and original, then you dont have a map sensor, you have maf sensor.
tpi didn't get MAP sensors until 1990
grease monkey girl
08-31-2004, 01:55 PM
oh. well I bought one anyway. guess i have to return it. I feel dumb now. :(
youngvr4
08-31-2004, 02:01 PM
you shouldn't we all make mistakes.
for the first 3 months of me owning my car, i thought i had 3.3 liters for some odd reason, even though it says under my hood 3.0 liters. not to mention the name 3000gt.
thats worth feeling dumb about.
4onFloor
08-31-2004, 03:26 PM
your engine is tuned port injection right?
grease monkey girl
08-31-2004, 07:35 PM
it most certainly is ;)
Dober89
09-01-2004, 05:00 PM
your tpi should be exactly the same as mine and it uses a maf sensor which is connected to the rubber boot thats hooked upto the throttle body
