300 E Drivers Window
pablo831
08-25-2004, 04:47 PM
My drivers windoe goe about 1/3 up and down and makes a grinding sound when it gets 1/3down I am trying to remove door panel and can only find one hex bolt on top of handle. It says there is one on the bottom and cannot find it. Is it behind the speaker assemmbly?
Any help is appreciated.
garryjwb
07-31-2005, 09:12 AM
Hi
I`ve had the same problem, could only find one bolt.
I eventually got the panel off and there wasn`t another bolt anywhere.
I got the panel off by first removing the trim around the adjuster for the mirror (you would already have removed the trim around the opener lever if you have removed the bolt)
The whole panel then has to be lifted up so that the top part of the panel is clear of the lock button on top. The panel is held in place by L shaped lugs that locate into holes on inner door frame (be careful has these seem to break too easily, once the panel is clear of frame, the door lever has to be pushed through hole in panel taking care not to bend the rod attached to opening lever, once this is done the panel should be free, fitting is exact reverse of the above.
Hope this is all clear, good luck
My problem was a white nylon toothed bush fitted between motor and lifting/lowering arms which had a few teeth stripped, I haven`t yet got round to removing motor/arms etc.
If you get to this point, please let me know how you got on..
