Radiator Fan wont kick in !!!
Frugo
08-23-2004, 06:47 PM
Hi,
my brother in law has a 1998 Plymouth Voyager, 2 days ago we ware stuck in traffic and the engine overheated, we pulled over, the coolant started boyaling ... whole 9 yards because the fan wont start up
we drove the car to a local mechanic, and left it there, he said it might be a relay, or temp sensor, so he replaced the temp and the fan still wont run, than he came to the conclusion that the computer has shorted out and doesn't send the signal, and needs to be replaced.
now I don't know if I should believe him or not. I found few used ECUs for $75 so if it comes to it, we'll buy one.
has anyone had a problem like that? what was the cause? and what should I look for?
btw. my brother in law was fixing dented door just before it happened. and he removed it without disconnecting the battery :sly: (yea, he forgot) so I think that's may be the cause of the problem
any help is appreciated
Thanks
Thanks
hundahunta
08-25-2004, 12:49 AM
possible fan relay... also try and spin your fan with your hand!! ***engine off, be careful*** make sure it spins freely!!
Bigjohnjr
08-26-2004, 03:13 PM
Rayy
10-01-2004, 11:55 PM
I've been there and found that the radiator fan connector was burnt. I replaced the connector on the bad side and cleaned the other side. It's been working fine for over three months. Good luck
ssixs
11-28-2004, 06:35 AM
Check with dealer on a recall for the fan relay. Had mine replaced awhile back, no charge, no problems since. :lol2:
vipergg
11-28-2004, 11:47 AM
I would get a second opinion , this sounds like a bad radiator fan relay problem which is a common problem during this era and most had recalls for this component because it was considered emmisions . I would take it to a dealer and see if it was covered under a recall .
casa01
12-15-2004, 08:18 PM
fan relay is located on the inner fender and is square (solid state)next to radiator driver side ...follow the wiring from fan and you will see it.
cost about $50 to $60. everything was fine after that.
