1993 Cadillac Deville Blower
lotris
08-21-2004, 01:09 PM
I own a 1993 Cadillac Deville and the AC blower will not shut off when the ingnition key is turned off. I have disconnect the control module and it still runs. I can get the blower off the disconnecting the plug from the motor or pulling the 30 amp fuse in the fuse/relay center under the hood.
Can you tell me what could cause this?
Thank You.
Thank You.
hyarnell1
08-21-2004, 08:05 PM
Common problem. Blower module is shot. Alot of other GM's of the late 80's, early 90's use the same module. Check salvage yards before going to the dealer.
