Carburator Flooding
QtDebbie760
08-20-2004, 09:12 PM
The carburator is a Rodchester 4-b. He has replaced the floats, they took the entire carb. apart, they said everything LOOKED fine. So back on the boat it went, SAME PROBLEM, he checked the Fuel Pump pressure--fine. Why does it keep dumping fuel??? It will start, idle for about three minutes then floods out and dies. HELP
86CamaroKid
08-20-2004, 09:18 PM
3 words......
FUEL INJECTION CONVERSION!
ridge_runner
08-20-2004, 10:05 PM
throw it away and get a holley... lol
did it just start?? or did you just put it on.... if you just bought it i would check the jet sizes and re adjust the carb.. or maybe they arnt adjusting the floats right
burnM
08-20-2004, 11:48 PM
Recheck the float level, and make sure the pin that holds the float is placed the right way (try flipping direction, may be causing it to catch) also check to make sure the needle is not snagging anywhere.
Edit; just to say, this ^^^ was the problem I had last year after I rebuilt the q-jet on my '85 Caprice. The pin that holds the float in position was flipped over in the wrong direction when I re-assembled it. I didn't think it would make a difference, but apparently it did...
68chevelle
08-21-2004, 03:12 AM
well like ridge and burnM said, its the float. its needs to be adjusted. it needs to be bent so that the float sits ferter away from the top of the carb more, (just so you know what way to bend it). but dont listen to ridge and far as the holley part, a holley will only work bettern than a quadrajet if one of the two following conditions are in effect...
1.the quadrajet was not tuned, (as probably 90% of all quadrajets are really truly tuned), and the holley had over 5 hours of good tuning, or...
2. ridge got ahold of the quadrajet with his sledge :icon16:
ridge_runner
08-21-2004, 12:03 PM
lmfao....:lol2:.. the holley thing was a joke
68chevelle
08-21-2004, 06:58 PM
lol. i know. i just thought i would poke a little more fun at you and your sledge.
351wStang
08-21-2004, 08:22 PM
I agree, it probably is the float. Unless its just way too big of carb all together.
ridge_runner
08-22-2004, 02:05 PM
lol..... R.I.P. sledge
NailZ69
08-22-2004, 07:01 PM
Get a 700 holly bwahahaha
ridge_runner
08-22-2004, 07:06 PM
750 dp
351wStang
08-22-2004, 09:42 PM
hell just get a dominator :)
ridge_runner
08-22-2004, 11:32 PM
haha.... yea then trade me....
