lights shown on the dash board
gelcol
08-20-2004, 11:37 AM
I got 1989 4 cylinder camry warning light bulbs on and sometimes turn off by it self I've done the visual check at the rear tail lights,headlights and signal lights every thing is werkin. I dont know why it keeps on showing the warning lightbulbs. does it happened to anyone?
ishop4less
08-20-2004, 12:44 PM
Your brake light is out. to check it press the brake while the engine is running the light should come on again, ask someone to take a look in the back which side light is off, then replace it.
Joe W
08-20-2004, 03:16 PM
Don't forget to check the center brake light.If all of these are working check the wiring harness around the trunk hinge.
gelcol
08-22-2004, 01:26 PM
my 3 brake lights are off going to check the black box it happeneds b4.
gelcol
08-24-2004, 01:35 PM
I mean yellow box found burnt resistor and diod where can i found the color code value for this anybody knows?
