spraying questions.
fz158
08-19-2004, 06:44 AM
About to spray my tamiya S2000 model and am a first time modeller. I wanted to ask when I am spraying both the primer and the actual spray paint, how far do I hold the can away from the model, and say i am spraying the side of the car; how quickly should I move the spray can across the car. i.e. how many seconds should I spend moving the can from the from one end to the other.
I would appreciate all the help you can provide.
Thanks
Zak
freakray
08-19-2004, 06:51 AM
Did you read the tutorial in the FAQ and How To section?
fz158
08-19-2004, 07:53 AM
yeah i read the tutorials but none say how quickly ou should spray across the model.
mikemechanic
08-19-2004, 07:57 AM
Depends on the type of spray can your using, practice, practice.....
http://www.automotiveforums.com/vbulletin/t14192.html
fz158
08-19-2004, 08:15 AM
am using the tamiya spray range. I thinks its the TS range. The ones they recommend you use.
Vric
08-19-2004, 08:32 AM
Tamiya did a tutorial for newbee:
http://www.tamiya.com/english/scale/beginner2/2.htm
there is even a video, if you don't understand after that, modelling isn't for you :D
