Please help! Window circuit breaker
Tom Crippen
08-18-2004, 03:37 PM
I just bought a new window circuit breaker for a 1992 newer styled 325i
and forgot which wire plugs in where, could someone please help?
thanks
bimmerman333
08-19-2004, 10:21 AM
doesnt matter all the switch does is open or close the circuit so it actually makes the two wires make contact to close the circuit, it don't matter
Tom Crippen
08-19-2004, 11:09 AM
Thank you ever so much!
bimmerman333
08-19-2004, 03:13 PM
is it your windows locked up on you , if it isnt the breaker ,then it is your comfort relay located under the dash under steering wheel.
Tom Crippen
08-20-2004, 07:07 AM
I tried the circuit breaker last night and nothing!
there isn't a fuse for it either, and if it wasn't for you I would have no idea ! I'll try that thanks!
bimmerman333
08-20-2004, 08:27 AM
comfort relay cost only $17 at bavauto.com.
Tom Crippen
08-23-2004, 11:20 AM
You are the Bimmerman !!!!!
=) it was the courtesy relay, it had a broken solder
right in the middle, there is a web site some guy has that shows how
to repair it and it worked !!!!
thank you ever so much for your help .. I owe you a Mountain Dew !
thanks again,,
crip
zgermans
08-23-2004, 11:40 AM
hey crip...what problem did you have with your window? my passenger window has been acting funny for a couple of months now...everytime i try to close it it stops...the only way to close it is to keep pushing the button until it fully closes...this problem isn't really consistant either...it will do this half the time i use the window...maybe this could be a quick fix if this is what happened to your car...thanks for your time...
bimmerman333
08-23-2004, 11:51 AM
zgermans your problem is just the window switch not making good contact replace the window switch and it should work
Tom Crippen
08-23-2004, 12:05 PM
Naw mine just quit working all together, sunroof and windows, Bimmerman has the answer,
later dude
bimmerman333
08-23-2004, 12:33 PM
happy to have been able to help.
zgermans
08-23-2004, 12:48 PM
thanks guys...i found a switch at bavauto...when i get in ill let you know how it went...thanks again
bimmerman333
08-23-2004, 12:54 PM
good luck
Buddhalux
08-25-2004, 04:38 AM
Which relay is the comfort relay? I just want to go ahead and order it without pulling my kneed bolster out.
bimmerman333
08-25-2004, 09:31 AM
i think it was the top left one behind the dash under the steering wheel.
Tom Crippen
08-26-2004, 11:29 AM
Hi guys!
I typed in comfort relay off the msn server and it took me to
LET
mail.roadfly.com/petah/E36comfortrelay.htm
this gentleman shows step by step how to repair the relay at no cost!
and it was easy,, if i can do it any body can
and it has worked fine since,,
crip
