85' GT possible HP increases?
85FieroGTspeedster
08-17-2004, 03:50 PM
Hi I have a 85' GT w/ stock v6 and auto trans. I was wondering if their were any good ways to get the hp up to about 200+. I have heard that engine swaps in automatic trans' arn't too wise. So I guess I am looking into turbo/super chargers, ram air, etc. Any tips? I am willing to do an engine swap but it will depend on the cost/time/gains in hp/ and compatibility of car. Any suggestions on what I should do, I woudl like to take this to the dragstrip and beat some rice burners.
Old Lar
08-17-2004, 07:45 PM
It is not easy to get 200HP out of the stock Fiero V6 that is 19 years old. Engine swaps are endless. I had a 3.4L crate engine and a 440T autommatic put into my 88GT. It makes for a good highway cruising machine. Not a dragster.
The nicest swap is a 3800SC engine, usually tied to a t460 (hydraulic) automatic or 460E (electronic auto). These put out 240-260 HP depending on year engine. If done by an experienced mechanic using a nearly new engine transmission, you are looking at up to $7K.
You could get a Northstar V8 with the 460E auto and get quarter mile runs in the 11-12 second range.
You can get a SBC V8 such as a ZZ4 355HP from www.v8archie.com or other engine. But HP & Fast and cheap don't mix.
So if you have $10-12 K to spend, you can get almost anything you want. :2cents:
Ragtop_Renegade
08-18-2004, 09:05 PM
I haven't done it with EFI and straight valve iron heads. I can get 250hp out of a 2.8 block with splayed valve aluminum heads & carbs, though. If you're interested enough I can list the whole setup. It's quite the small novel to explain lol.
