Fuel cut off switch
onwhiskeycreek
08-17-2004, 01:25 AM
Is there a fuel cut off or interupter switch on a 89 350 TBI suburban and if so where is it located?
Thank You Gary
95silverado
08-17-2004, 08:51 AM
I don't think you have a fuel cut off switch. Ford has them, but I'm almost positive GM don't. Can you hear the fuel pump run for a few seconds when you turn the ignition to the on position?
SpitAndDirt
08-17-2004, 09:02 AM
You might, however, have a fuse that is not easily seen. It is located right above the distributor connected to the fuel pump relay, screwed into the firewall. Just pull the connectors out one at a time and you may find the fuse burnt out. Possibility of a fuel pump going out. -Chris
