1997 Gt Stutters
contra
08-16-2004, 10:06 PM
Hey everyone here is my problem:
My car starts to stutter or hesitate when it reaches driving temperature.
About 10-15 minutes into my driving, when I press on the gas pedal it feels like there is no power and it jerks.
Ive changed wires, roto, cap, plugs and feul filter but problem persists. Help.
boschmann
08-17-2004, 11:31 AM
Which engine do you have?
contra
08-17-2004, 04:03 PM
2.0 manual trans
1994GLS
08-21-2004, 07:57 PM
have you thought about the injectors ? also check the fuel rail.
if not, try messing with the ignition timing (ONLY if you know wut you're doing)
contra
08-27-2004, 04:25 PM
I think my problem has to be heat related because it start either when my car reaches driving temperature or from the start on a hot day. Any takers?
boschmann
08-27-2004, 05:44 PM
Have you looed at the coil for cracks, spray it with water & see if the problem gets worse.
contra
08-27-2004, 05:59 PM
ok ive done the water test and all is fine.
amccarte
01-03-2005, 01:48 PM
Try tighteniing the distributor nut, my boyfriend had that problem in his '97 Jetta GLS and the timing was off too.
boschmann
01-03-2005, 07:22 PM
Pull each plug wire from the distributor cap (one at a time) & look to see if there is any deterioration. How long since the ignition parts were serviced?
kentond
03-02-2005, 03:42 PM
Buy a new gas cap.
I had the same problem with my '94 GL. I tried everything aswell and then someone told me about a gas cap problem, where the gas cap doesn't allow air into the tank, resulting in a vacuum in the tank, and various symptoms upstream from there. I usually felt the stutter when it was hot outside (>20°C).
I haven't felt one stutter since I replaced the gas cap!
good luck.
good luck.
