Another question
tacoma man.
08-16-2004, 06:33 PM
my 99 taco, just rolled over to 125,000 miles, is it time for a tune up? i beleive that she may have factory spark plug's and wires. are Bosh platinum 2's good? i mean will they damage my pistons and rings???? my brother recomended them.
Brian R.
08-16-2004, 07:03 PM
No, they won't damage anything. I would recommend using the factory-specified plugs.
TGates81
08-16-2004, 08:40 PM
factory plugs are denso-every bit as good as bosch if not better and they'll be oe.
Brian R.
08-17-2004, 12:06 AM
Denso or NGK dual electrode
Faze2183
08-17-2004, 12:07 AM
denso irdiums
Brian R.
08-17-2004, 11:26 AM
Vroom2
08-17-2004, 12:48 PM
Sorry to barge in... Brian R., or other tech gurus... can you explain to a stoopid user why there are no plugs listed for an '04 V6 Tacoma on the sparkplugs.com site? I've heard from a few other folks on toyotatruckworld.com that traditional spark plugs aren't used. This seemed strange, but it could be that I don't crawl out from under my rock often enough.
Thanks in advance...
Take care,
Jerry
Take care,
Jerry
TGates81
08-17-2004, 07:57 PM
they probably aren't listed because that engine uses the two prong grounded electrode plug. Dont know why they do but you can get them at the dealer for a reasonable price believe it or not.
wrigley123
08-18-2004, 04:55 AM
There's no listing for an '03 either?
Brian R.
08-18-2004, 09:41 AM
The 2003 and 2004 5VZ-FE engine uses the same plugs as it did in previous years. Denso or NGK dual electrode. If you need a number, order the plugs for a 2002 Tacoma 3.4L V6
NGK Multi-ground plug 4302 BKR5EKPB-11 $11.71
or
Denso Multi-ground plug 3289 PK16TR11 $7.16
I guess by "traditional plugs" they meant single electrode plugs. The 5VZ-FE engine has used the same plugs since 1996.
I don't know why they haven't updated their site for these years, but it's not because of the engine.
or
Vroom2
08-18-2004, 03:14 PM
Thanks for the great information!
Is it fair to assume the same is true for the 2.7L and 2.4L fours? A couple of friends have noticed the same thing...no parts listed.
Take care,
Jerry
Take care,
Jerry
vuthie
09-18-2004, 12:43 AM
Bosch plugs have a reputation for bustin' the electrodes into the engine....
Brian R.
09-18-2004, 12:46 AM
Unless they make a radical change to the engine (big hp change or turbo), the previous plugs will work.
