ECU for my setup???
omega_2099
08-16-2004, 05:17 PM
Guys, I searched the forums for an answer to my question and could not find one. If I overlooked the answer I apologize and post the link to that thread. Now onto the topic at hand.....
I have a '93 Prelude with a JDM 94 H22. I am running a custom T3/T04E turbo kit and have an exhaust and str adjustable cam gears. I am in the process of getting a MSD ignition, RC 440 injectors, Fuel rail, and adjustable fuel pressure regulator. Im currently running low boost due to stock bottom end. That come down the road but not soon enough. I am also waiting on a vafcII to comeso i can get that installed. I need to find an ECU that will work best for my setup. Will the stock p13 be the best ecu or does hondata make one that would be better? Any help would be appreciated.....
djdxm
08-17-2004, 01:12 PM
I would suggest a Hondata. They should make a application for your car. You can checkout what ECU's you can use with there system by going to http://www.hondata.com/engines.html
If your more technically inclined, You can look at using a Uberdata.
http://www.ecimulti.org/uberdata/ However I am not sure if they have prelude maps/support yet. But worth looking into.
Jay
91civicDXdude
08-18-2004, 08:52 PM
so you're running low boost.. what are you currently doing for fuel management? from the sound of it, you're using stock injectors with no mention of even a very lowly FMU...
civickiller
08-18-2004, 10:51 PM
he said rc 440cc
hondata or uberdata or aem
91civicDXdude
08-19-2004, 08:32 AM
he said he was in the process of getting them, i assumed that he was driving the car without said mods for the time being :P
civickiller
08-19-2004, 02:27 PM
i would hope hes not driving around with a turbo kit on an untuned motor
pheurton-skeurto
08-19-2004, 10:07 PM
who sells hondata, i cant find a site that actually sells hondata.
civickiller
08-20-2004, 01:22 AM
www.hondata.com
