97' Camry Cruise Control Problem
Redstrife
08-16-2004, 04:47 PM
I've been trying to work on my girlfriends car to get her cruise to work. Right now it work intermitently. The cruise light will always go on and I checked to conection on the cruise control actuator it seems to be fine. Before I start trying to trace the problem into the column I need a second opinion. I am lead to assume the problem isn't electrical. I think there must be a mechanical switch on the lever and I'm guessing it must be that. If anyone has an opinion please tell me. Thanks.
burchard
08-19-2004, 05:49 PM
I had an erratic problem with the cruise control. I checked everyhing in the actuator box and I could not find much. Finally, just by accident, I touched very lightly the brake pedal while the cruise control was activated and the cruise control went off. I adjusted the brake light switch located on the upper part of the brake pedal. I just moved about a mm towards the engine. That solve the cruise control problem. I gess the contact was wearing out and was not doing was it was suppose to be doing. Hope your problem is that simple also.
Redstrife
08-29-2004, 10:42 AM
Thanks burchard I'll have to check that. Perhaps the contact is grounding it out.
