o2 sensor
Talibangunner925
08-16-2004, 01:46 PM
Hey i was getting my o2 sensor fixed bit even when the new one was put in it was still reading the o2 sensor bad (possibly the harness). However i was planning on taking out the 2 after cat o2 sensors any way so i cold put in a cat bypass. I was wondering if there was any way to take out the 2 sensors and and not make the check engine light go on i dont think the after cat o2 sensor dont do much becuse in 98 they took them out.
marked001
08-16-2004, 02:11 PM
I know they make electronic devices that are called 02 simulators...havent heard of anyone using them on audis..but I dont see why they wouldnt work.. search for em..
might wanna get someone with a VAG to clear the code out off the ecu...then see if it comes back..
Talibangunner925
08-16-2004, 04:27 PM
thx alot sound like just what i need. Also idk what are you talking about with the other thing about clearing out the code but i did buy a a code read out meachine and i did try to clear out the light but after a few minuts the car relises that there is still somthing wrong and givs me the light again
marked001
08-17-2004, 08:14 AM
yeah..tha'ts what I meant.. so I guess the code is still there.. yeah..I guess you'd better check the wiring... you replaced both sensors?
Talibangunner925
08-18-2004, 12:00 AM
well i know one of the o2 sensors are bad and i have found out that not only is the o2 sensor bad but the harness is to so once i get that fixed i waill see what happens then later on i want to get rid of the cat ne way so i am goingto put a o2 simulatior later and see how that goes
