map sensor causing rich cond. on 2000?
kevkel
08-15-2004, 08:59 AM
hello all,
i have a 2000 blazer here and have a couple questions that maybe some gm techs will help. will a faulty map sensor cause a bank1 and bank 2 too rich faults on a mass air flown vehicle. my map sesor is reading 10hg. i dont have a vacuum gauge readily availible to see acual vacuum, but i know its not at 10hg by the way its running and idling. i always thought that on a mass air flown sysytem the map sensor was used as a dignostic tool for the pcm. is this not the case on this blazer. i already changed the leaky injector in the cfi unit and it helped but im still running rich, more on bank2 then bank1. whaddyathink?
thanks
kevin
BlazerLT
08-15-2004, 04:39 PM
Is the O2 sensors saying it is running to rich?
Have you done a tuneup with plugs cap wires, air filter etc.....
kevkel
08-15-2004, 06:32 PM
yes, the sensors are indicating that it is running a bit rich. did not do a tune up , has 40k on the odometer. jsut confused on why the map sensor reads 10hg of vacuum.
thanks
