1993 Grand Am SE dies when idle
EnzoreDax
08-11-2004, 07:26 PM
Okay more problems with my car, it dies when its ilde or when you slow down fast, some times when it dies, you start it then shift into drive or reverse it immediatly dies again. Any Help would be appreciated thanks.
billa_gts
08-13-2004, 04:10 PM
I had that same type of problem with my 94.. It was my ignition box the mechanic said and the liquid inside leaked out and shorted out my spark plugs and the wires... Was about $840... but your problem maybe different. Good Luck :smokin:
EnzoreDax
09-04-2004, 11:14 AM
im geussing no one has an idea as to why itd be doing this? auto zone says it might be the oxygen sensor, and the dies when shifting is something wrong with the tranny, I need a second opinon that knows what they're doing
Madcat455
09-04-2004, 12:37 PM
Alittle more info on your car might help a bit.
What size engine...
Milage...
When It dies.. does it run rough.. stumble, sputter...etc. Or is it like you're turning off the switch??
Have you checked the ECM for any trouble codes yet??? a bad O2 sensor would've definatley set a code before going bad. BTW.. engines will run without the O2 sensor.. they go into a pre programmed setting on the puter.
They will die if you're having problems with the TPS, IAC, MAF, ECM, CPS,.
Checking for trouble codes is the most logical first step. As that might identify a bad sensor.
HTH.
mrrob
09-04-2004, 10:18 PM
Here is a possibilty, I have seen many 3.1 V6 that have a problem with the electronic harness which controls the passing gear, You can see when looking at the transmission from the front a square plug, try unplugging it then go for a drive, if this corrects your stalling then you have to replace the solinoid pack( with harness) it is replaced by removing the pan on the side of the transmission.
I have changed lots of these, if you call your GM dealer he will know what your talking about.
Good Luck!
Mr.Rob
Lic Auto/Truck/Trailer Ect.... Mech!
jvmrn
09-09-2004, 04:02 PM
you could also chec you IAC valve. (idle air control)
richtazz
09-10-2004, 11:02 AM
you have a sticking TCC (torque converter Control) solenoid. IF you unhook the plug at the top passenger side of the trans like MrRob said, and it stops stalling, you found your problem.
EnzoreDax
09-10-2004, 07:05 PM
This is the engine,
4 Cylinders 138 3 2.3L MFI SOHC QUAD.
Thanks for the info on the tranny I'll look into, but any links or anything on how to check those things other then the Onboard Computer, would be nice. (not talking about the tranny there)
firebalz72
10-20-2004, 02:11 AM
i have a 92 se with a 3.3 just got it dont know much about it yet but its doing the same thing itll run fine for a little while then it seems if i hit the brakes a little hard it starts sputtering and wants to stall but if i get back on the gas it wont stall till i stop the itll start up fine in park soon as i try to put it in any gear drive or reverse my friend told me to unplug something on drivers side on the top close the motor on the tranny but didnt help still couldnt get it in gear let it sit for a while and it started and moved then did the same thing again so please help us im having second thoughts about this beautiful car!!
firebalz72
10-20-2004, 02:25 AM
i also just changed plugs and wires and since ive had it no check engine light has come on but ill test it and check on that also my check gages light comes on and off every thing looks fine all the gages are reading fine could it come on because of a blown out illumanation bulb or something please help if you can
