91 4Runner shifting problems
Hc4al04
08-09-2004, 05:00 AM
It does not shift out of first untill it reaches 4500 rpms then it shifts out of 2nd at 3500 then 3rd at a about 4 1/4 and 4th at 4000. What could be my problem?
Brian R.
08-09-2004, 08:48 AM
Engine thermostat. Your shift points are temperature controlled.
Hc4al04
08-09-2004, 06:48 PM
I was looking under it today and noticed that the cable running down from the throttle was broken. I think that might be my problem, what do u think?
Hc4al04
08-09-2004, 09:57 PM
Ok, sry. The cabel wasnt broken. But if it is the thermostat would it not be running different at different temperatures? Mine is running the same when cold and warm.
Brian R.
08-09-2004, 11:24 PM
If your thermostat stays open, you never get to operating temperature. May not be the thermostat, but it is likely.
Hc4al04
08-10-2004, 12:42 AM
ok, well I will try it. Thanks for the advise
Brian R.
08-10-2004, 09:42 AM
You're welcome - This is a common problem.
