Rear axles
Jake_E
08-08-2004, 04:53 PM
I came across a 1988 Ram 150 ½ ton van recently with a shot 10 bolt 8 3/8 rear. I was told the rear was replaced twice. I’d like to know if a 9 1/4 rear could be fitted fairly easily without heavy modifications.
Links, experience or any relevant information on the subject would be appreciated.
frankendart
09-13-2004, 06:55 PM
You might want to check into things like the drive shaft length, spring purches locations, brake backing plate interchangability, brake line connections, and shock mounts.
Jake_E
09-14-2004, 11:40 AM
I heard there were 9 1/4 rears used in 88 vans. I was kind of hoping someone here had replaced their 8 3/8with a 9 ¼. From what I read the 8 3/8 is 27 spline and the 9 is 31. . I believe that is correct? I know from appearances the gear housing between the two is completely different. Most important for me are the mount locations. I don’t have the facility at this time to relocate mounts or replace parts opening the housing. I figure the easiest solution would be a direct swap, possibly changing the yoke if needed.
frankendart
09-14-2004, 06:31 PM
DO you have a line on a good used 9 1/4? You can probably find one at a junk yard, you might need to find a B200 or B250 to get on. If you do, see if you can get the drive shaft, too.
Jake_E
09-21-2004, 03:54 PM
I believe at this time I will have to rely on measurements locating a replacement rear at a yard in the hopes I can fit one from a heavier duty van. It has becoming somewhat difficult to find information in text form regarding replacement as I have mentioned.
Thank you for your replies. .
