any ideas
eightcylS10
08-06-2004, 10:42 PM
i have an 88 s10 long bed with a 305 automoatic(TH350), and its putting out about 200-210 HP. i also have a stock rear end. my question is any ideas on wut my 1/4 mile times will be? im guessing high 14's, thanks for the input.
big1
08-11-2004, 06:50 AM
With the stock rear I wouldn't be doing a lot of drag racing.
Could you give a little more information?
What rear gear ratio are you running ? What size tire ? Will you be manually shifting the ttransmission ?
It's been my experience that the S10 can make for a very fine drag truck if set up properly. You will need some sort of traction devise, such as traction bar's and probably 90/10 shock's up front and 50/50's on the rear to help transfer the weight.
14's could be possible, given enough time run's and tuning.
