starting problem
dlinh747
08-05-2004, 09:23 AM
hello alll,
When I push down the emergency brake pedal, it pinched one of the wire (green with black stripe)..now my van still crank up but not started. I checked the fuse box in the glove box...they are OK...someone told me the fuse link might be bad...but I don't know where to find it under the hood or what it look like...Please help...I need this van by this saturday..
Thank in Advance
Thank in Advance
frankendart
09-13-2004, 05:04 PM
It's called a "FUSABLE LINK", and if it goes, nothing works, not even the starter.
What year van, and which engine do you have?
I've got a book that I can trace the wires in, but I need to know the year of the van.
Some of the cause of an engine cranking, but not starting could be:
Out of gas,
carb problem,
Choke not working right,
water inside the distributer cap,
a cracked cap, or a grounded lead,
fouled plugs, or loose plugs
Bad Magnetic pick up coil,
low compression,
Bad coil,
gas not getting to carb
timing chain jumped or broken
bad gas or water in gas
bad ignition wires or loose wires
vacuum leak
loose power break booster hose (vacuum leak)
loose PVC hose (Vacuum leak)
bad coil wire primary or secondary
also check the Baallast resister, or dual ballast resister.
hope this helps.
Out of gas,
carb problem,
low compression,
Bad coil,
vacuum leak
hope this helps.
