anyone know about upgraded ignition systems?
perna00
08-04-2004, 04:18 PM
i was curious about how much of a difference performance plugs, wires, coils, ec. . . made with the 3.0. i've heard that you really can't tell a difference unless you have a FI system but was curious about the gains/cost. thanks.
johnnyBgood
08-04-2004, 06:40 PM
Gains are not going to be noticed until you have massive performance modifications already done. There is no upgrade forthe system either, only plug wires from Nology, Magnecore, etc.
Shpyder
08-05-2004, 03:24 PM
upgrading your ignition system means a few things....a stronger battery, wires, plugs...and if you want a higher VOLTAGE...the secondary turns in your coil pack....but you cant notice anything until u have a crazy list of mods to make use of an upgraded ign. system
Sleepr awd
08-06-2004, 12:53 AM
The actually mits dealership people will tell you not to mess w/ the wires, the ECU in the 3g is funny about having stock wires, anything different will make it mess up as for the actual spark plugs i'm not sure
perna00
08-06-2004, 11:10 AM
thanks for all the info. if i decide to got with a FI setup should i worry about the ignition system or would if sufficiant?
johnnyBgood
08-06-2004, 12:50 PM
Don't worry about it until you get to the full standalone level.
