d16a6 or mpfi swap in dx.
2ndb18
08-04-2004, 02:05 PM
what do you guys think would be a better way to go, is it worth the more money to just buy the whole d16a6 engine or should i just do the mpfi swap. also how much power would i be behing the d16 if i did the mpfi swap. and how much would both ideas cost ,thanks
91civicDXdude
08-04-2004, 06:16 PM
D16A6 - 108hp
D15 MPFI (OBD0, d15b1/d15b2) 98-104hp estimated
TheSilentChamber
08-04-2004, 07:24 PM
just to the mpfi, easy cheep and will put you to almost the exact same hp at a whole si motor swap.
dssmax
08-05-2004, 04:27 AM
Hrmm,
If you have the time and the D16A6 is in good shape then I'd do the swap..
If you are pressed for time and your D15 is in good shape MPFI..
I tell you this, I did a MPFI on a D15 and its like a whole other motor... With the old automatic I was able to spin the tires (13") from a standing start where as with the DPFI I was never able to do that..
MAX
MAX
