94 Geo XFI Engine mild surging
sixseas
08-04-2004, 11:56 AM
I have a 1994 Metro XFI 5 spd runs perfect except it developed a mild surge. It most noticable in the upper range of each gear and when crusing. I has new gas filter, timing, plugs, ECM reset but still cant pin put my hand on the problem. :eek7:
geojim
08-04-2004, 05:06 PM
Can you relate the surging to use of the A/C? If it only does it when the A/C is on, then it may be the A/C Idle Air Control solenoid, or it's vacuum hoses. That was the case on my '93.
sixseas
08-04-2004, 09:00 PM
Thanks GeoJim Ill check the hoses again. It doesnt have AC. I suspect it fuel related some how by the way it feels also seems like the engine lacks the power it had. Was running perfenct before they ran it through emissions test.
mik13usa
08-04-2004, 10:17 PM
always check the vacuum connections after the pros at the emmissions test center get done!
geojim
08-05-2004, 06:16 AM
And your tailpipe to make sure they didn't leave the potato in. Just kidding...
sixseas
08-05-2004, 05:00 PM
Im checking all connections and looking for taders so far all looks like its in great shape. So far it still has a surge in the upper range of each gear. She was running perfect before it was abused on the emissions treadmill.
westsidex
08-07-2004, 02:56 AM
Tsk tsk tsk Geojim. We know Metro XFi models don't have A/C! :wink:
