No spark?
rnitsudr
07-31-2004, 12:16 PM
95 Tbird. LX 8 cyl
I have no spark at all, The coils, wires and plugs were replaced 2 months ago. Should I replace the Ignition control Modual or should I check something else first?
rnitsudr
08-01-2004, 09:00 AM
I replaced the Ignition Control modual from another thunderbird and there still is no spark. Does anyone have any ideas?
ModMech
08-01-2004, 05:17 PM
No spark is usually no crank signal. If it has a Tach, and the tach reads zero (or under 100 RPM) while cranking, replace the Crank (CKP) sensor. Lower RH side just inboard of the A/C compressor.
