SLP CAI and PCM Location
stlwagon
07-29-2004, 05:40 PM
With an SLP CAI is the PCM located inside the CAI box (like with a stock box) or do I need to buy a PCM tray? I know the Thrasher CAI comes with a poly carbonate tray but it looks like the SLP holds the PCM inside. Thanks.
s_jo4
07-29-2004, 05:48 PM
it's located inside the airbox, you might want to get some velcro or zip ties to secure the pcm in the airbox.
stlwagon
07-29-2004, 05:58 PM
So it doesn't fasten inside the box like stock? Will the velcro keep it from bouncing around?
s_jo4
07-30-2004, 07:11 PM
to some degree i'ld assume, never liked the velcro idea unless it was in an already tight area. but you can just drill a couple of small holes and run the zip tie through it and that'll hold it in place pretty good.
stlwagon
07-30-2004, 07:38 PM
Thanks. Will try that. Don't want the PCM bouncing around. I've found that vibration and electronic devices don't mix well.
