just to make sure (shifter linkage)
anthony90si
07-29-2004, 03:08 PM
is the one from a b16a and a1 the same as b18a. (all the b series and the same right)
91civicDXdude
07-29-2004, 06:22 PM
no they are not. it depends on the car it came from. If you get an SiR B16A (there was no B16A1 in JDM or USDM, only european markets got an engine actually called "b16a1"), then the shift linkage will fit on the EF chassis. Most b16s you get are from integra XSi, in which case are identical to the DA 90-93 USDM integra linkage, which is about 2-3" too long to use on the 88-91 civic/crx chassis without modification.
mellowboy
07-29-2004, 08:22 PM
Yep. Just grab one from Hasport. It should be 150 or less.
anthony90si
07-30-2004, 04:29 AM
i bought a likage from avidracing witch says (B16A B16A1 B18C 1 B18C5 Civic/CRX Avid Shifter Linkage)
dang what did i get myself into.
will this fit in my car
turtlecrxsi
07-30-2004, 09:29 AM
It is probably just advertised that way to work for B series swaps into our cars.
mellowboy
07-30-2004, 01:25 PM
Yes.
Yes.
anthony90si
07-30-2004, 03:27 PM
alright cool thanks guys..
