Tire pressure Light
2Koldsalero
07-29-2004, 08:58 AM
Does anyone know why the tire pressure light comes on and stays on even after the tire are filled and also how to turn it off.
Thanks in advance 2Koldsalero
crystalilmama
07-29-2004, 11:13 AM
All you have to do is use your reset button on the side where your fuses are located. I had the same problem and I took it to the dealership and they showed me how to do it.
JTrujillo86
07-30-2004, 04:19 PM
Take the fuse panel cover off on the driver's side of the dash. There is a big red RESET button. Hold that for 5 seconds until the CHANGE OIL light flashes. Then give it one more good push (without holding it). The LTP (Low Tire Pressure) light should flash. Finally hold the RESET button for five more seconds and the light should go out. BTW you have to have the key in the ON position without the engine running to do this.
JeReMy
ugsrich
08-06-2004, 09:09 PM
Read the Owner's Manual, it is a veritable font of information.
JTrujillo86
08-06-2004, 09:38 PM
Some people don't have the owner's manual.
Jeremy
