Throttle cable bracket
teocdoc
07-28-2004, 06:47 AM
I have a 1985 4x4 S-10 Blazer and am attempting to change out the motor (2.8l). This is my first try at something like this. I have gotten everything disconnected for removal except the bracket that holds the throttle cable. It has two bolts holding it to gasket cover as far as I can see but when I remove them, the bracket still won't come loose. What am I doing wrong? Also, there appears to be a wire attached to the back of the motor against the fire wall. I can see it when I'm looking from under the vehicle. What is this?
dugie6551
07-28-2004, 07:48 AM
Instead of taking the bracket off, just remove the throttle cable from the bracket. Get a "straight" screwdriver and push on the plastic tabs that holds the cable in the bracket. It is much easier this way then removing the bracket. If you need the bracket for the new motor, pull it off when the motor is out of the truck.
teocdoc
07-28-2004, 04:05 PM
Thanks for the info. I thought about that but wasn't sure if I might break something going that route.
smokey041369
07-29-2004, 08:44 AM
that wire on the back of the engine is a ground strap
