Right Tire Started Squeeling
SMOKEY818
07-27-2004, 05:26 PM
My Right Front Tire Has Been Squeeling For Some Time, Well Today It Has Really Started Squeeling, Could It Just Be The Breaks?
DaMoNe6969
07-27-2004, 06:15 PM
Most likely your brakes.. Take the tire off and check the wear indicator on the pad.. If your pad is still good and the wear indicator is rubbing the rotor, bend it back a bit with plyers..
you could also have gotten a small pebble or rock in the pad.. but they usually will break away or fall out right away
SMOKEY818
07-27-2004, 06:41 PM
Thanks, I Also Heard Semi Metallic Brakes Are The Way To Go.
housy_bigmike
07-27-2004, 07:28 PM
ceramic
ceramic
SMOKEY818
07-27-2004, 07:31 PM
I Thought Ceramic Made Too Much Noise,well Screw The Noise Which One Will Stop My Car Faster
drvngstorm05
07-27-2004, 11:40 PM
i heard the semi metallic ones leave alot less brake dust. which one stops faster? i don't honestly have a clue, if u wanna stop faster get some drilled and slotted rottors. those things look pimp too :naughty:
Chevyracincamaro
07-28-2004, 12:05 PM
im pretty sure the more ceramic that you have in the pad, the more noise it makes at operating temp. ceramic pads perform better though...
pro_am
07-28-2004, 07:00 PM
I have ceramic, and they work great, opted for them over the carbon metallic.
Jake
Jake
