92 Metro auto trans shifts too early
DMC12
07-26-2004, 10:17 PM
I have to manually move the shifter from 1 through 3, or else the tranny decides to go 1-2-3 before 15 MPH. Any ideas?
Thanks for the help!!!
westsidex
07-27-2004, 04:03 PM
Sounds like your throttle valve cable needs to be adjusted.
blackstone
07-28-2004, 04:13 PM
My 2000 had a similar problem. It turned out to be the back up light fuse, which also powers the solenoids that shift the transmission. (mine stayed in 3rd at all times) I don't know if this is a similar car, but it might be worth checking.
DMC12
07-28-2004, 06:46 PM
Sounds like your throttle valve cable needs to be adjusted.That is the cable sitting on top of the tranny, right?
westsidex
07-28-2004, 10:21 PM
There are two cables on top. One is the shifter. It's on the left. The one on the right is the throttle valve cable. Sounds like it's too loose.
