How to get codes
Silverado Brethern
07-26-2004, 07:25 PM
my SES light came on intermitantly for a while and now has been on solid for over a week; however nothing is wrong with the engine that i can notice. i understand that there is a way to get codes from the diagnostic port by checking the number of times the light flashes and at what pace. does any one know for sure how this is done??
broughy84
07-26-2004, 10:01 PM
if it is a 95 or newer you can do this, you jumper terminal A and B the two most right and on the top row. this will help www.troublecodes.net/gm
Thunderbolt
07-27-2004, 09:55 AM
You mean 95 or older you can ground the A and B. 96 and newer require a scanner or a code reader.
broughy84
07-27-2004, 04:49 PM
yeah that's what i meant, sometimes i type faster than i can think! :)
Silverado Brethern
07-27-2004, 05:19 PM
so could i rent a scanner from like napa or some place like that?
Willie0508
08-09-2004, 02:08 AM
there some thing worng because a chevy will reset if the problem goes away
Willie0508
08-09-2004, 02:10 AM
that a chevy though but if you have a friend with a hypertech power programer that you can clear and read the DTC codes the ses light normal only come on when it break emssions but that should help
