Truly how fast?
HondaSpeed
07-25-2004, 06:22 PM
How fast is a 1995 Honda Accord EX with an H22A engine and turbo. How fast can it be? I want a good sleeper, something with suprise. I love my car. After these changes how fast can it be!?
f22burnout
07-25-2004, 10:51 PM
If you wanted a true sleeper just use the stock engine and boost it. Stock on the f22b1 holds boost really well cause they only have 8.5-8.8 comp. At 9lbs they due round 240whp. This would also save you a lot of money to do what ever else.
92lx
07-26-2004, 12:31 AM
Umm, last post doesn't make a lot of since. And the f22b1 holds boost, relatively well. The h22 holds just as well, and will put out over 240whp. I don't think a "stockish" f22b1 with 9lbs of boost is going to put out 240whp. It'd be very lucky to put out 233 CRANK horsepower...
why, because the basic estimation of horsepower from boost is calculated as ((<psi>/14.7) + 1) * BHP.
In which case, I get around 230-240hp, but that's at the crank.
Anyhow, an h22a engine with turbo...depending upon the boost level is going to run low 13s, or lower....... assuming a pansy amount of boost, low 13s...assuming tuned and with higher boost levels.....I'd say 12s are POSSIBLE, but there are a lot of variables.
Turbo = very audible, not much of a sleeper.
- Nathan
HondaSpeed
07-26-2004, 01:33 PM
Yeah that's true the turbo is kinda loud, but if I keep everything stock outside, then at least at a ligth or on the freeway it will be a sleeper. And I will be running low boost at first so... How ready is the H22a to accept a medium/low boost turbo?
