rusted old exhaust manifolds
emailer33
07-23-2004, 09:29 PM
1993 ford thunderbird lx 3.8l
well i'm trying to remove my exhaust manifolds, and it's hard enuf with them right against hte wheel well, adn teh fact that they are rusted to shit just makes it worse. i got all the exhaust man->cylinder head bolts, but only one of hte pipes to manifold nuts on both sides. the ones i can't reach are both covered by a heat shield on both sides of the car. anyone got any pointers/ideas to get these off? I tried removing the LH heatshield, but the bolt is so rusted it just rounded it, and i didn't use a bit that was too big :P. If anyone has any information on how to get this off or just make it easier, plz share. Thanks everyone.
flewthecoupe
07-24-2004, 02:27 PM
I had to remove the left front tire and splash shield. After that I could get to the collector bolts. Forget about removing the heat shield...
emailer33
07-24-2004, 03:07 PM
hmm ok, so you never took off the shield?
emailer33
07-24-2004, 07:09 PM
hmm how about the RH side? cuz there's a solid block of metal in my way :P
emailer33
07-25-2004, 12:06 AM
well i finally got one of them out, and looking at them, they're in very ugly shape. So which would be better:
Getting out my wire brush rotary tool and cleaning them off
Or buying new ones (definitely want to get new bolts).
I trie dlooking for het manifolds or just the bolts alone and I could not find either. So can someone direct to where I can find these things? Thanks in advance.
Car Pal
07-25-2004, 09:11 AM
wow! you are really determined to remove those studs aren't you? oxy aceteline torch? dangerous! safety first.
emailer33
07-25-2004, 09:38 PM
well one side the nut is stuck and by turning the nut i ended up removing the stud itself w/ the nut permanently attached. thus why i want to get new manifolds or at least new bolts
flewthecoupe
07-26-2004, 03:35 PM
Clean what you have the best you can and use anti seize on them. On the right hand side I had to use a swivel and some extensions and a few cuss words.
emailer33
07-26-2004, 05:36 PM
thx for all the tips guys, but what if i just wanted to buy new ones? Anyone know a place?
emailer33
07-28-2004, 08:19 PM
nobody at all knows?
flewthecoupe
07-28-2004, 10:01 PM
Midas? Meineke? Bud's Muffler Shop?
emailer33
07-29-2004, 01:31 AM
so you're saying i can get just the bolts by contacting them?
flewthecoupe
07-29-2004, 10:27 PM
I don't have a clue. But if I needed new bolts I would imagine they would have or could find new ones due to having the same problems we had.
