Please Help PI OIL COOLER LEAKS
HotRodVic94
07-21-2004, 12:04 PM
I have a 94 crown vic PI and these models came with a ford engine oil cooler mounted right behind and underneath the radiator.My problem is its not leaking from a hole in the 2 hoses coming out of the cooler and leading to the block.Its leaking from the metal fittings that conect to the oil cooler.so i took the fittings off and sure enough there use to be 2 little rubber I think washer(gaskets) about the size of a nickle hollowed out.and i can't get any replacement parts for this I've tried every web sit I can think of and I tried typing in the # on the unit to see if maybe I can just find the cooler and go from there,but everytime I type the # in at OEM FORDs part center it says part can't be found.my last resort is to use RTV silicone I really don't know what to do.Please if your a Ford Lover like me you know that this is driving me nuts and ANY help or advise is very welcome -----------thank you 4 your help
ModMech
07-22-2004, 10:30 AM
They are just common A/C "O-rings", any decent parts house should have them.
HotRodVic94
07-22-2004, 01:53 PM
[QUOTE=ModMech] Thanx man thats exactly what I needed thank you thank you thank you.I just needed another mechanical mind to help me out with such a stupid little problem thanx again it worked like a dream:)
