Any good ways to take apart a pre-glued kit?
DSM-Mark
07-21-2004, 11:35 AM
At a second-hand store I found myself a Tamiya RX-7 R1 kit for $2.99 CDN!! Problem is, whoever had it first glued much of it together. Other than that, this kit is complete. I'd love to get the engine out and use it in my C-West RX-7, but don't want to damage it. None of the pieces are painted.
Any ideas, or should I, "just pull"?
g00eY
07-21-2004, 11:41 AM
i just pull on my kits but i have to be careful. sometimes my old kits arent glued together that well anyways, and sometimes they are stuck.
StephenDeli
07-21-2004, 12:00 PM
Im not sure about this and maybe someone else might know but I would think that soaking it in brake fluid or some kind of thinner would dissolve the glue and the pices would come free??
jswillmon
07-21-2004, 12:01 PM
you can buy superglue remover at walmart that breaks down gule somewhat so you can pullit apart.
DSM-Mark
07-21-2004, 12:04 PM
Really? I've never seen that. Any ideas if it's safe for plastic? I guess that might be a "try and find out" answer...
Murray Kish
07-21-2004, 12:14 PM
A trick I learned is to put it in the freezer. If it's put together with superglue, the joints will pop apart quite easily after it sits in the freezer for a while. If it's put together with a plastic glue (testors, ambroid, tamiya, tenax, etc.), then the joints are probably going to be a bit tougher. They'll usually pop apart, but you might need to cut into the joint a bit with an exacto knife first (to weaken the bond.)
Murray
Murray
mike@af
07-21-2004, 12:21 PM
I've been wondering the same thing, because I will need to glue some stuff together, modify the main piece, then dissassemble it for paint.
jswillmon
07-21-2004, 12:52 PM
I'll let you know when i get home, i put it on the front bumper of my civic hatch b/c i'm now going to use a sas bumber and it would not come loose in the front. no damage could be seen last night, the stuff smells pretty stout but i don't think it's gonna harm it. Hell, i don't even know if it's gonna work b/c the plastic has already bonded pretty good and it can't get between the 2 pieces.
mike@af
07-21-2004, 01:38 PM
Im working on testing the freezer method.
mike@af
07-21-2004, 01:41 PM
Well the freezer method works. If there are globs and globs of glue its going to take longer. For me I just stuck and old B16 engine in the freezer for 10 minutes and pryed the pieces off gently with an X-Acto. I had glued the pegs, as well as the flush edged together.
