more wiring diagrams needed - 94 bird
Neggy
07-19-2004, 12:05 PM
Well I fixed my last problem with the injectors, now its time to takle the next one...
Im going to do some rewiring of some of the stuff under the dash on the drivers side above the gas and brake peddles. Sometimes the brakes light dont work and from time to time it has a tough time coming out of park when I push on the break. All of this is because of a mess of wiring on the drivers side. The people who had it before me did a crappy job putting in an anti-theft device.
Anyway, if anyone has these diagrams I would be thankful if you would share them. Im not 100% sure which diagrams I will need, but hopefully those 2 things will be on the same diagram.
emailer33
07-19-2004, 01:31 PM
well hope this is enuf, it's the whole instrument cluster.
dunno how the instrument cluster wiring would affect your transmission's performance tho :/
http://home.indy.rr.com/emailer33/images/94indash.jpg
Neggy
07-19-2004, 01:49 PM
Thanks for the diagram emailer33, but not the one I need. Let me see if I can explain the diagram I need a little better. Its hard cause I dont know exactly what i need but ill give it a shot.
On there brake pedel there is a switch called the stoplight switch. Im thinking that that might have something to do with why both my brake lights are not working all the time and why I can't put it into drive all the time when it is in park.
On my 94 you cant take it out of park unless the break pedel is inguaged, so there is something (hopefully just the stoplight switch) that isnt always doing what it is suppost to.
Im betting there is a diagram that has to do with the brake lights and hopefully it has something in there about the 'take out of park only when brake is pushed'
I hope that makes since.
Again thanks for that diagram, I saved it already and it will come in handy later on when I work on the display lights.
emailer33
07-19-2004, 02:48 PM
for that, you wanna look at the shift lock actuator.
here's that diagram:
http://home.indy.rr.com/emailer33/images/shiftlock.jpg
instead of a wiring error, it could just be that the actuator itself is going out. (that's in the steering column). here's a pic of locations:
the brake on/off switch is in F7, and the actuator is in A8.
http://home.indy.rr.com/emailer33/images/locations.jpg
if you still want the light diagrams themselves, lemme know, but i think this should be what's causing it.
Neggy
07-19-2004, 07:04 PM
Ah Thanks a lot man, that explains a lot!
I am forever in debt to you good sir!
