smoking tail pipe
90_hondaCivic
07-19-2004, 12:26 AM
When i start my car it smokes real bad and when i rev it a little bit it does a lot to. Just driving it smokes but not as bad. Does any body know what it could be? It just started doing it. I changed the oil about 3 days ago. If you put your hand in the smoke it smells like gas.
maxassassin
07-19-2004, 02:31 AM
i think your probably burning oil or soemthing or your cats fuck over or the possibility that yoru gas is old or to low of a octance booster. so i recommend use octance boost and engine cleaners for the feul injection and seals and stuff
90_hondaCivic
07-19-2004, 01:48 PM
yeah it is burning oil. The dude i got the car from didnt drive it for 2 years. It just sat in the drive way.
Hybrid1990crx
07-19-2004, 01:58 PM
If it smokes real bad when you first start it and runs alittle wierd then its your headgasket. I know this from experience. But I'm sure you would have smelled the coolant.
civic_geek133
07-19-2004, 02:00 PM
a valve may be stuck or something since it was sitting
take out the spark plug wires one by one and see if it the idle changes, if it doesnt for one of them then you either have a stuck valve, broke valve, or the spark plug is bad or the wire
hope that made sence. check that and get back
maxassassin
07-19-2004, 03:55 PM
i suggest a full fluid change and tune
spongerlbc
07-19-2004, 04:15 PM
Chances are its your valve seals. I had the exact same symptoms and my compression was 195 psi accross all 4 cylinders. I replaced my valve seals and the smoking stopped.
90_hondaCivic
07-19-2004, 06:01 PM
there is some kind of smell but im not sure what it is. there is also some kind of short or something that drains the battery. so when i get out i have to unplug the battery so it dont drain any of you guys know what i should do bout that.
90_hondaCivic
07-21-2004, 03:42 PM
Thanks
