Check Engin Light On
StickyMits
07-18-2004, 09:46 PM
Hey,
Just installed a turbo back exhaust system, extra long downpipe that eliminates the cat and then a catback apexi n1, on my 95 eclipse GST. After i drove for about thirty miles and my check engine light came. Imediately I thought that one of my sensor was tripping the light. My questions are...first, is this a correct assumption? second, how do i get the light to turn off so i dont have to ride around with it on. Is there any way to remove the sensor...does that work? Has this happened to anyone out there. Dont know what to do, please help. Thanks.
ashah000
07-18-2004, 10:38 PM
Probally a CEL for the cat. You can do a resistor mod for it. Otherwise it won't go away.
Nstyle29
07-18-2004, 10:58 PM
well once you think you have it fixed unhook the battery for a few min that is how i got mine off...but if it isn't fixed then it will come back on
cky86
07-19-2004, 01:45 AM
Ya u can just take it to autozone too they will check it for free.
dsmith3075
07-06-2008, 11:59 AM
2003 s10 engine light staying on.Had GM dealer check ,code indicated PO1071 fueL trim lean.System test showed that fuel pressure was low,I needed a fuel pump.I put on the pump & drove 75 miles & the light came back on...any Ideals???
ned032002
07-06-2008, 09:09 PM
Please post in the correct forums, your in the Eclipse, Talon, Laser area and you also resurrected an old thread so please go to the right area before posting again.
heyyo302
07-17-2008, 10:29 AM
It may happen in any model or make car. First remove your gas cap and reinstalled it to drop the vacuum pressure and to check engine light will come on all the time. If you are handy, go out and disconnect the POS. Post of THR battery. Leave it off for 15 to 20 minutes. This will erase all failure codes and reconnect the terminal. No light, no more problem
