I was wondering
driftking777
07-17-2004, 07:02 PM
I was wondering if i buy a 3sgte motor if i could use the 5sfe tranny to keep it front wheel drive...another question...does the 3sgte have the same motor mounts as the 5sfe motor? if i could just bolt the motor in and have the 5sfe bolt up...that should solve my problems right? if not tell me what is needed for the swap.
driftking777
07-19-2004, 05:42 PM
Does Anyone Know...?
90GTkid
07-19-2004, 08:30 PM
i dont think you can use the tranny you've got unless you want to do a custom job. I've seen other people who used a FWD tranny but they had to weld it and modify it to fit, and when you start doing that you tend to get week spots. in other words... its usually breaks! i think going with an AWD tranny is the logical choice... that is if you can get your hands on one....
jimbobillybob
07-20-2004, 04:08 PM
http://www.everythingcelica.com/ubbthreads/index.php
try asking it here in the gen specific forum also you need the wiring harness and ecu and alot of patience
http://www.celica.net/main.asp
analogvoid
07-21-2004, 12:54 AM
The chasis code on toyota's give a hint to what motors fit in a car. For example your celica is a st18X, i beleive.. the s in the front of the chasis code means it will take an S series motor.. 5S, 3S.. etc. My celica is a ZZT231.. it should take various ZZ series motors.
driftking777
07-22-2004, 07:23 AM
so what your saying is that a 3sgte motor will fit...but i have to change everything to awd...or weld on my tranny according to 90gtkid...anywho...if you can enlighten me on that...go for it
90GTkid
07-22-2004, 06:25 PM
you can check this thread, it will tell you a little about what i was getting at.
http://www.automotiveforums.com/vbulletin/showthread.php?t=250061&highlight=celica+sale
driftking777
07-22-2004, 06:58 PM
i see what you saying now i thought you were saying the tranny had to be welded in but you were saying the axles basically have to be custom made and snap easy right?
90GTkid
07-22-2004, 07:47 PM
ya, sorry if i confused you, but yeah, basically you have to modify the axle, the tranny and maybe some other small stuff depending on which tranny and engine you have. sorry if i wasn't clear...
