Help replacing window regulator??
carlypederson
07-16-2004, 10:18 AM
I have a 2001 Alero 2 door, and I need to replace my window regulator and motor. I have the parts, I just need some help with replacing it. Is there a site somewhere that shows exactly where the clips are and some basic instructions on how to take the door panel off? Any help would be appreciated!!
2000alero
10-13-2004, 12:45 AM
I just popped my door panel off.
First, you need to pop off the cover under the handle you use to pull the door closed. There, you'll find 2 phillips screws. Then, it's easy.
With a long flat tip screwdriver, you need to pry the door panel away from the steel frame. The panel is pushed in place with small clips. Also, if you have a tweeter up in the corner, that pops out as well.
From there, the dorr panel should pop off and all you'll need to do is unhook the wire harnesses.
Dave
